Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Any guides on changing positive battery cable?
Old Apr 29, 2017 | 09:07 AM
kaivorth's Avatar
Default Any guides on changing positive battery cable?
I plan on replacing the corroded terminal. I have a new positive terminal with 2 screw on 8 gauge openings. Can I cut off the corroded wire and just plug in the bare wire into the new connections without issue?
Old Apr 29, 2017 | 06:34 PM
JPat's Avatar
Default Re: Any guides on changing positive battery cable?
What do you mean by two screw on connections? any pictures?
Aslong as it is a real automotive battery terminal you cant go wrong. Just check it for tightness whenever you get the car serviced
Old May 7, 2017 | 09:43 PM
prodjay10's Avatar
Battery terminal replacement guide. (this should be stickied)
1) Remove
2) Replace
Tcoy23
Apr 24, 2014 12:17 AM
dpdawson
Dec 1, 2008 09:17 AM
simonEp3
Jun 25, 2008 01:11 PM
mxl360
May 7, 2008 11:36 PM
kustomize89
Nov 2, 2003 07:45 AM
