96 Accord Clutch Master Cylinder issue
Old Apr 27, 2017 | 10:20 AM
eevan1963's Avatar
Default 96 Accord Clutch Master Cylinder issue
so i've got this converted AT to Manual 96 accord that is giving me trouble with the Clutch Master Cylinder leaking from the pedal side , so i replaced it once the ms and the slave , and it was working ok for like a month so now i notice the pedal is going soft again and saw a small leak on the ms .
any one with this similar issue ?
or what can i do to fix it for good this time ?
thanks
Old Apr 29, 2017 | 02:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 96 Accord Clutch Master Cylinder issue
If your CMC was a rebuilt unit it may be the problem, only use new or rebuild them yourself.
If the pedal was not properly adjusted or bled correctly you may be over stroking the CMC and failing the cylinder.
Make sure there is no junk in the lines that may be floating down into the CMC and failing/rolling the seals.
collkid
Feb 23, 2021 03:20 PM
03djmAccrd
Jul 8, 2010 01:37 AM
nigelalan
May 8, 2010 07:13 AM
tato1983
Dec 11, 2007 05:52 PM
st95accord
Jun 3, 2005 04:27 PM
