Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Flashing D4
Old Apr 26, 2017 | 05:35 PM
O.G's Avatar
O.G
Icon5 Flashing D4
Hi guys,
I got a problem with my Honda Civic 2009 Dx, the problem is flashing D4 and check engine light is on stuck on 2nd or 3rd gear. So the OBD II got troubleshoot is P0843 which is a transmission fluid pressure sensor. And I got the part but I can not find where it goes in. So please help me out. Thanks.
Old Apr 27, 2017 | 06:43 AM
foumer's Avatar
W95 gives me a hard-on
Default Re: Flashing D4
Have you checked and changed the transmission fluid? Here is a diagram where its located, assuming its this code.
P0843: Open in Transmission Fluid Pressure Switch A (2nd Clutch) Circuit, or Transmission Fluid Pressure Switch A (2nd Clutch) Stuck OFF
Old Apr 27, 2017 | 05:01 PM
O.G's Avatar
O.G
Thank you for replying me, I have not checked or changed the transmission fluid. What do I need to do? Change the fluid or just need to change the sensor?
Old Apr 28, 2017 | 05:22 AM
foumer's Avatar
How many miles? I would do both just in case. Check the level first, you might be low.
Old Apr 29, 2017 | 09:37 AM
O.G's Avatar
O.G
So I will check the fluid level, does it have a dipstick? Where can I find it?
Old Apr 29, 2017 | 09:40 AM
foumer's Avatar
1.To check the fluid make sure the car is parked in a level surface, and that the engine is cold.
2. Turn on the car and while pressing the brake run it through the gears slowly P-N-D-3-2-1, then back up to park (P).
3. Turn off the car and let it sit for 10 minutes or so.
4. Check the level.
Below is a video where the dipstick is located.
samkim0108
Oct 30, 2010 12:09 AM
brianjung818
Jan 16, 2010 05:59 PM
I'm Trying
May 20, 2007 04:17 PM
EFin' Kyle
Jul 22, 2006 09:18 AM
BigJohn
Apr 20, 2003 04:04 AM
