92 Accord F22
I'm replacing my head gasket, and the people who did it before obviously did not do their research. They reused the head bolts and a lot of the head bolts tension while breaking them lose were inconsistent. Now what I want to know is, when I'm using the torque wrench what do I set it to? Irregardless I'm going to read the manual and do further research but I really like using these forums to gather my information. Being that I'm a newbie when it comes to wrenching on cars. Any hints and tips on making sure I get the best outcome of this headgasket replacement would also be great.
There are three stages and you have to go in the correct sequence. You optimally want to use the beam torque wrench but you can use the click type of you go real slow and make sure not to over torque. Obviously use new head bolts. You can get away with using the old ones if the head wasn't warped but obviously that's not the case with yours so you will be getting new ones.
runderwo
May 17, 2006 10:48 AM
50shotRex
Jan 28, 2003 08:50 AM
