What is this part (fell out of valve cover)?!
So long story short, I was removing my valve cover to replace some gaskets and this tiny oval shaped piece seemed to have fly out of the valve cover while I was putting it down (potentially not even from the valve cover but it fell onto the ground as I was putting the cover down). Absolutely no one I've asked has any idea as to what this is or where it goes and I for the life of myself can't figure it out either as nothing seems to be missing on both the valve cover and the head. I should mention that it wasn't covered in oil or anything either which makes me thing it potentially isn't even from the valve cover...
Anyone have any ideas? Thanks.
It is a spacer found in the plastic cover of the engine harness as it passes across the top of the valve cover... at either end of where the coil plugs are located.
