BWR billet shifter bushing rattle
Im currently running a K tuned pro circuit shifter with the billet shifter bushings and this thing rattles like CRAZY. Everything was installed correctly. Has anybody had the same problem? Id like to know my options to fix it before I rip these things out my car and go with normal bushings.
Are you referring to the bushing back by the shifter that bolts to the floor (underneath the car) or the one that is attached to the transmission?
I am running the BWR two piece billet bushing on the rear with a skunk2 dual bend shifter and a Dimes shifter bushing at the transmission, no rattles or issues. I know the two piece BWR bushing on the rear is a two piece and has alignment dowels on it, are you sure those seated properly?
I know they only recommend running aluminum shifter bushings if you have very stiff or solid engine mounts.
I have both it came as a set, it only rattles from the shifter. If i put my hand on it it either lowers the amount of rattle or stops it completely. I have hasport mounts theyre stiff. I checked the allen key screws on the shifter itself everything is still tightened down.
darnizzle8805
Jun 20, 2014 06:04 PM
The_Honda_Guy
16
Nov 28, 2009 06:09 PM
