Rack and Pinion Bellow
Old Apr 19, 2017 | 06:01 AM
DudeEX's Avatar
Default Rack and Pinion Bellow
Will 53534SR3N52 work as a replacement for 53534ST0013? I ask because at rockauto, the SR3 (Moog K9863) comes with the retaining clip/tie but doesn't mention that it's compatible with the other assumed left side ST0. For a 2000 EX Coupe. Thanks.
Old Apr 19, 2017 | 04:26 PM
DudeEX's Avatar
Default Re: Rack and Pinion Bellow
Dang! I guess it's a dumb question. ST0013 does list that it's compatible with SR3N52. I guess that answers my question.
Old Apr 19, 2017 | 05:50 PM
mk378's Avatar
It works fine to just use a wire tie (zip tie) to hold it to the rack if you don't have the official metal tie.
Old Apr 20, 2017 | 05:51 AM
DudeEX's Avatar
Will 53534ST0013 fit on both the left and right side?
Old Apr 20, 2017 | 06:10 AM
mk378's Avatar
That I do not know. Usually the left and right ends of the rack are different.
Old Apr 20, 2017 | 09:45 AM
DudeEX's Avatar
Regarding the zip ties, I see on the DIY by petr0lb0mb, the spiral one can be reused. And, I've read that the other end could be reused as well if you carefully lift the tabs that hold it in place. Easier said than done, maybe
abcdefg123
Suspension & Brakes
Jan 18, 2011 01:56 PM
96hb
Suspension & Brakes
May 1, 2010 10:38 AM
96hb
Suspension & Brakes
Dec 14, 2009 12:18 PM
holdenw172
Honda Civic (2001 - 2005)
Feb 7, 2009 09:45 AM
eric416
Aug 15, 2005 06:22 PM
