98 hatch blinker problem help!
Old Apr 18, 2017 | 04:59 PM
Brawnz328's Avatar
Default 98 hatch blinker problem help!
hi guys here is my problem..I replaced fuse and relay and still no blinker not sure it could be a ground or a short of some sort maybe some of u guys have had this same problem I will continue to search to see if anyone on here had the same problem thank you in advanced guys..also the cluster rpm,speed,gas and temp don't work just some lights on there like seatbelt light etc maybe this problem is related.thanks guys
Old Apr 19, 2017 | 05:21 AM
mk378's Avatar
Default Re: 98 hatch blinker problem help!
Does the hazard 4-way blinker system work? It uses the same bulbs, mostly the same wiring and blinker relay, but a different source of power.
If it's not a blown fuse, there is a break (open circuit) in one of the circuits. Inspect the fuse box and plugs for melting or burning.
Old Apr 19, 2017 | 08:15 AM
Brawnz328's Avatar
ok I will check that thank you very much for your help sir
Old Apr 19, 2017 | 10:53 AM
NVturbo's Avatar
O.G. triple O.G.
It's a blown fuse. $5 bucks says it's the illumination wire behind the radio, coming in contact with metal.
nukefivesix
16
Feb 9, 2010 06:51 PM
XRacerX
Sep 9, 2009 08:50 AM
rkot
Jul 4, 2007 11:28 AM
drtyhatch
13
Dec 14, 2005 04:43 AM
