CA 1998 Integra Type-R
Back-up for sale, buyer had issues with shipping. Taking back up offers.
Selling my 1998 Integra Type-R. Car is only driven maybe 2-5 times a year for shows. Engine is started up bi-weekly to ensure everything is running fine. Rebuilt title due to theft. Options below.
I have owned the car for about 3 years and I did the kswap conversion. Originally had a B-series. I have spent a lot of money and elbow grease on this car. No corners were cut. People that have seen my car at recent shows can vouch how clean this car is.
Exterior is 9/10, no scratches, rust, dents, etc. Car was recently paint corrected by Properly Detailed
Interior is 9/10 dash is clean and all pieces are in tact door panels etc
Engine bay and trunk area have been re-sprayed last year
Chassis has 105k miles
Extended wheel studs all around
New centric rotors with posi pads all around
New wheel bearings all around
5 lug suspension
Buddy club front and rear camber kit
Buddy club lower ball joints
ITR 23mm rear sway bar
1998 Integra Type-R
Motor has less than 500 miles
K-Swap made 270hp on E85 on a dynapack
K24/k20 swap
Hondata v4 kpro computer
Hasport billet mounts
Type-S trans with Lsd
Comp Stage 3 clutch
Upgraded Supertech Valvetrain
Skunk2 ultra 2 cams
Cut and ported RBC manifold with 74mm matched Skunk2 TB with spacer
Hybrid racing fuel rail with 1150 E85 gram injectors
E85 grams fuel pump
Custom 3" Intake
Race traction bar
Arias 87.5mm 12:1 cp pistons
Eagle rods
King bearings
Oem crank
K-tuned AC/PS delete
K-tuned upper water neck
K-tuned lower water neck
K-tuned heater delete plug
K-tuned billet race spec shifter
K-tuned race spec cables with trans bracket
K-tuned Billet firewall cable plate
Custom fuel system with Aeromotive FPR and Hybrid racing fuel rail
Koyorad slim radiator with custom mounts
Power pros V-band headers
Hasport mounts
36mm innovative race spec axles
3" 304 stainless exhaust with all Vband connectors and Ktuned turndown exhaust
Custom catch can with Valve cover breather
More parts not listed
Oem Jdm ITR HID front end with carbon air ducts
Oem ITR metal hood
Oem ITR wing
Oem ITR hood
Oem ITR suspension
Oem ITR Interior carbon pieces with carbon switches and OEM center console with arm rest
Jdm Oem power folding mirrors with switch
Engine Bay is done with new wiring, fuel lines, tucked brake lines, $3k job
You will get milspec harness for k-swap with charge harness etc
Custom slim battery with mounting plate by passenger side fender
Jdm ITR cluster
UKDM Tails
Cusco 8pt D1 Chromoly cage
Jdm ITR black Recaros
Car will come with OEM ITR wheels.
Will only meet people at the police station to view the car.
No joy rides or low ballers
$16k
Call to buy 562-287-4922
