Performance, Honda Accord 93
Old Apr 18, 2017 | 11:55 AM
TheTix's Avatar
Default Performance, Honda Accord 93
Hello!.. well i'm from venezuela, and I have an Honda Accord EX 1993 2.2 With F22A Engine, when I turn on the car, tacometer goes to 2k and stay there for few minutes until the temp get 60º C, when I'm driving for a few minutes the S Light start to blink, and the car lose "Strength", dont change the gears correctly, and the overdrive doesnt works, but this happens just when the car gets turn on for a 10 minutes at least... if I drive with the engine cold, it works perfectly... All the "Pipes" is new, radiator.. engine and transmission have no more than 2 years... I dont know if may be a electrical trouble, broken connections, if could be possible to desmonut transmission and clean all the solenoids and valves, dont know really where to start but I need an Idea, may be the ECU? Thanks for you support
Old Apr 19, 2017 | 07:28 PM
LucciOne's Avatar
Default Re: Performance, Honda Accord 93
Yo se a que se debe el problema que presenta tu vehiculo, cuando quieras puedes llamarme al 414-0368384. Saludos.
Old Apr 20, 2017 | 12:25 AM
MAD_MIKE's Avatar
MM Gruppe B
If the S light is blinking then there is a code.
Look over on the passenger side kick panel, look for a blue two wire connector.
Jumper the connector.
Turn the ignition to II(ON)
Watch the D4 or S light for blinking. Short blinks are counts of ones, longer blinks are counts of tens.
Record codes and post them.
Zarkul
Mar 21, 2018 04:35 PM
TheTix
Jul 3, 2017 07:11 AM
Bobby Brand
Feb 28, 2017 03:31 PM
staudi24
Jan 31, 2009 02:44 PM
