Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
wiring diagram needed for civic 1.7 2003 and civic si 2005
Old Apr 17, 2017 | 11:11 AM
CLUTCH LADIES's Avatar
Default wiring diagram needed for civic 1.7 2003 and civic si 2005
I want to put an 2005 Civic Si Cluster into my 2003 Civic so I look everywhere to find the wiring diagram for both cluster and it seem I can't find it.
I have both cluster, both pin out schema, I just need to be sure that the wire have the same function on both car to redo the pin out correctly
Can anybody could help me with this issue?
Old Apr 17, 2017 | 07:30 PM
bbarbulo's Avatar
Default Re: wiring diagram needed for civic 1.7 2003 and civic si 2005
isn't the 03 and the 05 the same? I can't remember, but I put the newer LED cluster in my 2001, had some wires to switch around and one I think needed to be made longer. think the info I used was on 7thgenhonda
Old Apr 17, 2017 | 09:36 PM
toyomatt84's Avatar
Sanji
In the states, the Si is a hatchback (EP3 chassis). Its got a slightly different harness all-together.
Old Apr 19, 2017 | 09:04 PM
bbarbulo's Avatar
oh ya, true. i have the 'EX' cluster then from the kouki 7th gen - not an EP3 cluster.
daymkimchee
Mar 15, 2010 06:09 PM
Caoboy
16
Oct 1, 2004 01:15 PM
EF9Si-T
Feb 16, 2004 09:49 AM
