Option fuse
Old Apr 14, 2017 | 03:11 AM
Crocky's Avatar
Default Option fuse
I have a 1992 Honda Civic. Something is draining the battery. I have put a meter in the positive lead from the battery. I am measuring 1.5 amp draw with everything switched off, doors shut etc.
In the under hood fuse box I have removed a fuse one at a time. When I remove the option fuse the current draw drops to zero, but the car won't start!
Any ideas what the option fuse does?
Old Apr 14, 2017 | 09:11 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Option fuse
Can you provide a fuse number?
Under Dash:
Old Apr 14, 2017 | 11:50 AM
mk378's Avatar
So, check if anything is plugged into option plug #1 on the left side of the underdash fuse box.
Old Apr 17, 2017 | 10:31 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
If it's #36 then that's a major fuse!! Start narrowing it down by pulling fuses in the under-dash fuse box. Your service manual (you'd better have one!) will show you all the things #36 is connected to.
Old Apr 19, 2017 | 11:03 AM
NVturbo's Avatar
O.G. triple O.G.
You have a loose ground somewhere. They don't come loose, you or previous owner may have not bolted it down.
dhealey
Honda CR-V & Element
11
Jun 5, 2024 06:31 PM
monsterCHILD
Jan 6, 2011 04:28 PM
josh_db1
Jun 12, 2010 02:46 PM
Hanmin
May 16, 2008 02:17 AM
2LoW4FaThOeS
Aug 4, 2002 10:40 PM
