I have a kind of rubbing noise at lows speeds on 05 odyssey
It sounds kind of like a rubbing noise or something from rear brake area. at only low speeds is when you notice it. When your foot is on the brake it goes away. Not quite sure. Any ideas people. Ty for your time. I would have searched but i do need to make some posts to build up my account so i can use the marketplace as well. I used to be a member but its been awhile.
Remove the wheels and check your brake pads. They most likely need to be replaced.
On my son's 2005 Pilot the front and rear pads wear out almost simultaneously. So check the front pads too.
Good luck,
Sam
Good luck,
Sam
pear_b
Apr 11, 2009 12:21 AM
