I'm new to fixing cars and I need help fixing my Acura integra 95
Old Apr 12, 2017 | 05:36 PM
Shinobi_carlos2's Avatar
Icon5 I'm new to fixing cars and I need help fixing my Acura integra 95
The car won't start and people told me that it was the fuel pump so I changed it for a new one after that I tried turning it on and it still didn't work after that I thought it was the cables but somebody told me it might be the main relay so I also changed it for a new one and for my surprised It didn't work either so I need help what's wrong with it is the cables and how can I fix that ?
Old Apr 12, 2017 | 05:41 PM
tony_2018's Avatar
Fish Twig
Default Re: I'm new to fixing cars and I need help fixing my Acura integra 95
Learn to diagnose.
Old Apr 12, 2017 | 05:44 PM
I'm trying to but i still don't get it
Old Apr 12, 2017 | 06:32 PM
AYB18c's Avatar
Using the "search this forum" function on the main integra page (https://honda-tech.com/forums/acura-integra-6/) and searching for "car won't start" (with the quotation marks included) returns 434 threads that have to do with a lack of starting. There are may possibilities, fuel problem, spark problem, electrical problem, starter problem....it's going to be tough to determine what's wrong with your car without more information.
I suggest searching for "car won't start" on the main integra forum page and reading some of those threads. Maybe that will help you get an idea for which way to proceed. The link is below:
https://honda-tech.com/forums/search...rchid=20209084
Good luck!
Old Apr 12, 2017 | 11:49 PM
trm4life's Avatar
So simple diagnostics. Turn the key on, check engine light (CEL) should illuminate, fuel pump should prime, CEL should turn off. If your CEL stays on, your ECU is bad.
Old Apr 13, 2017 | 02:45 PM
wunfstgsr's Avatar
Loved
Community Favorite
Check your distributor/ coil and rotor and or check for spark! most common is a bad coil not firing.
Old Apr 13, 2017 | 04:29 PM
tamboo's Avatar
10 Year Member
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Old Apr 13, 2017 | 04:36 PM
Scorchin Civic's Avatar
Let me be the first to say welcome to the site! Like was mentioned above, see if your getting spark from your spark plug wires. Most common problem with Hondas of the 1990s is the coil inside the distributor.
Old Apr 13, 2017 | 04:39 PM
Hmm, so I should have bought a ecu instead of gas cap for my Integra? My check engine light would stay on but as soon as i replaced the gas cap it went away. STFU if you don't have something useful to say!
Old Apr 13, 2017 | 06:40 PM
trm4life's Avatar
Um, if u had a CEL for your has cap, it was on while your car was RUNNING. If the light doesn't turn off when turning the key on, the problem is the ECU. Now if you are driving and the light comes on, you can read the code and do diagnostics from there. Not the same thing
Old Apr 30, 2017 | 11:16 PM
Honda_ThuGZ's Avatar
Lmao this guy
Bethany87teggy
Jan 22, 2016 04:45 PM
ecollinscona
Oct 23, 2014 12:39 AM
WePoX
Dec 16, 2012 12:13 PM
rehab_this
Oct 18, 2005 07:12 PM
