AXLE SETUP H23 SiR EG HATCH
Old Apr 12, 2017 | 09:37 AM
BLUtop_H23's Avatar
Icon5 AXLE SETUP H23 SiR EG HATCH
IM PUTTING TOGETHER A H23 BLU TOP WITH A H22 TRANNY BUT IM STUCK ON WHAT AXLES TO USE... I NEED SOMEONE WHO HAS THIS SET UP IN A EG HATCHBACK. IM TRYING TO GET THIS CAR FIRED UP AND RUNNNING BY THIS WEEKEND ANY ADVICE WOULD BE HELPFUL!
Old Apr 12, 2017 | 03:49 PM
e30bimmer89's Avatar
Default Re: AXLE SETUP H23 SiR EG HATCH
I know some people have had issues with them, but I ordered the Yonaka axles as a temp thing for the time being until I have my beefier ones made for when I boost mine. A few other companies make them also, but they are a bit pricey.
Old Apr 12, 2017 | 06:34 PM
BLUtop_H23's Avatar
So you ordered H22 axles ? You didnt have any type of fitment issues? It seems like the prelude axles are longer..
Old Apr 12, 2017 | 08:29 PM
hifl's Avatar
I'm running Insane shaft axles in my ek h22 and never have had any issues. I have roughly 8+ track days on them with zero issues.
IS-001-IS-004 Insane Shafts
Old Apr 13, 2017 | 06:51 AM
BLUtop_H23's Avatar
INTRESTING.... SINCE IM ON A BUDGET... CAN I JUST USE REG H22 AXLES FROM 97-01 PRELUDE THEYRE MUCH CHEAPER FROM AUTOZONE. WILL THEY PLUG AND PLAY???
Old Apr 13, 2017 | 09:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Regular 5G Prelude axles will NOT fit an EG chassis... they are too long and the outer spline size is WAY bigger than the civic hub. I suggest you contact HASport or Raxles for a proper low cost set.
Old Apr 14, 2017 | 09:42 AM
Chance EG's Avatar
90-93 Accord 5 Speed intermediate shaft
90-91 Integra Driver side axle
90-91 Integra Passenger side axle.
https://honda-tech.com/forums/hybrid...mation-434668/
Also, learn to turn caps lock off. Seriously.
Old Apr 18, 2017 | 12:58 PM
I have their EG H22 swap axles. I haven't had a chance to install them yet because my swap isn't finished yet, but will be soon. My friend that had the same exact swap in his EG coupe used the Yonaka axles and they worked perfectly.
Shadowe622
Jan 16, 2013 01:32 AM
pullin crx hf
Aug 26, 2011 01:12 PM
Marcpb443
Jun 26, 2009 02:28 PM
Entaka
Feb 21, 2005 07:36 PM
