I have a 2000 civic ex that i bought last summer. the car came with some extra parts. I installed an AEM cold air intake that was lying around. I didn't see any way to secure the lower part so i zip tied it to the frame. After researching I found I have this bracket that bolts up to the tranny and will fit with the intake. My car currently doesn't have anything there. Am I missing the front lower tranny mount?
Part # 10, also parts 8 and 12. Yes it's important, it keeps the engine from rocking back and forth when you accelerate. Remove them from a junk car. You can upgrade part 8 if the rubber is bad.
Thanks for the reply. Hopefully missing this mount didn't damage any of the others. I'll go to the junkers on my next day off to get a hold of the parts.
The previous owners had the engine in and out a few times and must have forgotten to put that mount back on. At one point they were going to swap in a h-series motor, but it was stolen apparently. So i have some h22 conversion mounts/t-bracket, a p13 ecu and an obd2 to 1 conversion connector.
