2007 CR-V Alarm won't turn off
Anyone have any ideas on how to turn off the alarm? I have the battery disconnected right now. I am unable to put the key in the door and turn because the lock cylinder is busted and that's how I got in this situation in the first place. (I had AAA open my door and I was planning on re programming some key fobs in order to unlock/lock my door as a temporary solution.) I've already tried turning the car on which does not stop the alarm. Thanks everyone!
Look for an orange wire behind your interior fuse box. Use a jumper wire or something similar to ground that wire. This will disarm it (same effect as turning the door lock to the unlock position with they key). As long as you keep that wire grounded, the alarm will be unable to re-arm.
willyboyK20
Audio / Security / Video
Apr 18, 2002 04:51 AM
