wiring details
OK so I just bought a OBD0 to OBD1 conversion harness and I have a question on the wires that I have to manually wire up.
Connector A
Pin 23 PGI power ground
Pin 25 IGP2 Power source
Pin 26 LGI logic ground
Connector B
Pin 1 IGP1 Power ground
Pin 2 LG2 Logic ground
Connector A
Connector B
you shouldnt have to wire anything up except for the sensor wires that go to the engine bay (vtec, o2, etc..) unless of course your car is a dpfi chasss. in which case the jumper wont work unless you first set up your car for mpfi
I have a CRX SI so it has mpfi. I bought a ebay conversion harness OBD0 to OBD1 and a rywire one as well just to compare the two. and by the looks of it they are wired totally different i will post up more details after work
Yes on the vtec and I will be running the wires for the vtec solenoid, vtec pressure switch, knock sensor, map sensor, and O2. Will post pictures later of the differences between the 2 conversion harnesses.
Cheap Ebay Wire harness
Connector A
1) Purple wire = Pin 4 Vtec solenoid
2) Blue wire = Pin 6 Primary O2 heater control
3) Green wire = Pin 17 intake air bypass control solenoid
4) Black wire = Pin 23 power ground
5) Red wire = Pin 25 Power source
6) Brown wire = Pin 26 Logic ground
Connector B
7) Pink wire = Pin 1 Power ground
8) Black wire = Pin 2 Logic ground
Connector C
9) Orange wire = Pin 3 Knock sensor
10) Yellow wire = Pin 4 Service check engine signal
11) Grey wire = Pin 6 Vtec pressure switch
12) White wire = Pin 14 primary heater O2
Rywire conversion harness
Connector A
1) Black wire = Pin 4 Vtec solenoid
2) Brown wire = Pin 6 Primary O2 heater control
3) Red wire = Pin 17 intake air bypass control solenoid
4) Yellow wire = Pin 25 Power source
Connector B None
Connector C
5) White wire = Pin 3 Knock sensor
6) Blue wire = Pin 4 Service check engine signal
7) Green wire = Pin 6 Vtec pressure switch
8) Grey wire = Pin 14 primary heater O2
9) Orange wire = Pin 21 Sensor ground
10) Purple wire = Pin 22 Sensor ground
Let me know your thoughts and what one I should use? $25 vs $115
Connector A
Connector B
Connector C
Connector A
Connector B None
Connector C
BigChance
May 29, 2011 10:29 AM
Harry_Randal
Jul 13, 2004 06:47 PM
