2000 GSR Swap Quaife LSD Transmission
Old Apr 9, 2017 | 09:01 PM
olddohc's Avatar
Default 2000 GSR Swap Quaife LSD Transmission
$3300
RIVERSIDE, CA
Been putting this together for a couple years, just lost interest. 99% complete GSR swap. Complete rebuild. Its OBD2 and specific to a 96-00 civic.
BLOCK
2000 B18C1
81.5mm bore, ACL bearings, Arp rod bolts, GSR rods, Rs pistons, OEM head studs. Brand new OEM oil pump and water pump
HEAD
Stock GSR cams, Supertech valve train with receipts, keepers, retainers, valves, valve springs
Hondata intake manifold gasket
Blox extended intake studs
TRANSMISSION
1997 GSR
$1,000 Quaife LSD
Transmission has approximately 20,000 miles
B16 1st & 2nd
GSR 3rd-5th
Stock gears, stock synchros etc
I have receipts for most parts just have to dig them out. You will be purchasing from the shop Im at everyday. Case is off the transmission so you can look at that too. I prefer to sell complete but will part out with the prices below.
GSR transmission w/ Quaife LSD-$1300
GSR engine zero miles-$2200
Innovative mounts-$150
OBD2 P72 Ecu-$125
94-01 Integra linkage-$125
(Brand new bushings)
Brand new xtd Oem style clutch-$100
Billybobby
Sep 29, 2018 11:33 AM
MattTBrown
Apr 23, 2016 01:32 PM
D@nnY
Jun 5, 2008 11:24 AM
Samuels
Mid-Atlantic (Sales)
Mar 17, 2008 06:49 AM
DelsoldS
Feb 9, 2006 08:25 AM
