cooling fan malfuntion
Old Apr 8, 2017 | 09:28 AM
Bldg1023's Avatar
Default cooling fan malfuntion
The cooling fan on my 2000 Honda Accord LX is not engaging. The condenser fan is however. I switched the relays on the two fans and the cooling fan does still not run and the AC fan does. So I'm assuming that the relay is good. I'm not sure what to check next. I thought about straight wiring the fan to the battery to see if the motor runs.
Old Apr 8, 2017 | 09:56 AM
jollyhonda's Avatar
Default Re: cooling fan malfuntion
The fan motor may just be burned up. Have you checked all the fuses?
Old Apr 9, 2017 | 04:34 PM
holmesnmanny's Avatar
It could just be the fan. Apply direct batter to the fan using a set of test leads and see if it turns on.
1989 Honda Accord
Jan 3, 2013 06:48 PM
slow sol
Mid-Atlantic (Sales)
Sep 18, 2009 04:58 AM
Jdmsolutions
Nov 16, 2006 12:47 PM
