Door Actuator stuck, 07 Accord
Hi Guys, need your help,
I have a 2007 Accord LX. The rear door was not shutting snug. So when playing with the actuator ( the white plastic lock on the door) with the door open it got shut with the door open. Now the door wont shut as the actuator is in the lock position.
Do you have any suggestions as to what is the best way to unlock it?
Thanks in Advance.
Dan
Thanks in Advance.
Dan
Nevermind guys, I managed to fix it.
I had to depress the cutoff switch on the body frame and pulled on the lever inside the door as if I am opening the door and it released the hook/clamp.
I was stuck at Home Depot this morning when this happened and couldnt figure it out so I took some rope and tied the rear doors and drove home.
Thanks
Thanks
Shadowsstrife
Apr 21, 2017 06:51 PM
rubenmed
Nov 25, 2012 01:46 AM
