motor swap issues
Old Apr 7, 2017 | 08:13 PM
ctorres's Avatar
Default motor swap issues
have a 94 prelude si with a h22a motor swap, but speedomitor is not calibrated/correct/accurate
also im pretty sure my vtech is not kicking in, the previous owner dose not know anything about his issue, all the proper wire looks to be wired, even the vtech cylenoid valve is wored up. but not if it was done correct,
can somebody please help me figure this problem.
Old Apr 8, 2017 | 10:36 PM
1992BB2's Avatar
Default Re: motor swap issues
http://www.automotiveforums.com/t211...h22a_swap.html
See if the whoever did the swap, wired the VTEC correctly (or at all).
Old Apr 11, 2017 | 07:42 AM
ISUBIEXI's Avatar
Just a note, it drives everyone absolutely bananas when you spell VTEC as VTECH. You may want to edit that, you may get more responses. lol. Also maybe spell check the rest as well, some people are very petty and wont reply if they think your a dummy.
Wire up a light to the Vtec cyl , that way you can ensure its kicking in. If the speedo isn't working its possible that the computer is not seeing the minimum speed for Vtec to kick in.
Ensure that the VSS is installed and properly seated, it can take a little maneuvering and the mounting tabs tend to snap off, if the mount is broken it could be bouncing around in there.
Old Apr 11, 2017 | 10:04 AM
snobordboy's Avatar
Moderator
Yup, the VSS is likely the root of it all, or at least the main culprit.
daveypower
Jan 1, 2013 03:10 PM
badassgixxer
Sep 3, 2008 11:07 AM
ProjectTib
Apr 17, 2007 08:50 AM
preludeMOM
Mar 19, 2007 10:44 AM
NONKonformyst
Jan 13, 2002 07:51 AM
