Performance and Protection for the Honda S2000 Roadster Sports Car
K&N is dedicated to providing quality products that offer premium performance and protection for your Honda S2000. Replacement air filters, cold air intakes and heavy-duty canister oil filters are some of the performance upgrades available from K&N.
The K&N replacement air filter for the Honda S2000 was engineered to fit into your factory airbox without any cutting or fitting. This simple design makes adding performance to your S2000 as easy as removing your stock paper filter and replacing it with a K&N. Our OE replacement air filters are backed by a million mile limited warranty so it's the last air filter your Honda S2000 will ever need.
Air Filter E-2435
for the Honda S2000The K&N replacement air filter for the Honda S2000 was engineered to fit into your factory airbox without any cutting or fitting. This simple design makes adding performance to your S2000 as easy as removing your stock paper filter and replacing it with a K&N. Our OE replacement air filters are backed by a million mile limited warranty so it's the last air filter your Honda S2000 will ever need.
K&N cold air intakes for the Honda S2000 are guaranteed to increase horsepower. They are engineered to provide virtually unrestrictive air flow to your engine. K&N removes the restrictive factory air filter, air box and intake housing and replaces it with a high-flow K&N air filter and custom intake tube that is designed to smooth and straighten air flow to your engine.Testing has shown an estimated increase of 9 horsepower at 6500 RPM with K&N's 57-3514 fuel injected performance air intake. This non-metallic high-flow intake system was designed to fit 2004-2008 Honda S2000 models with a 2.2L engine, and 2000-2003 Honda S2000 models that have a 2.0L engineK&N's 69-1040TP, using a polished aluminum intake tube, and 69-1040TWR, using a red powder coated intake tube, were designed to dramatically reduce intake restriction allowing more air flow to your engine. Both intakes show an estimated gain of 5 horsepower at 5220 RPM during dyno tests. These intakes will fit 2004-2005 Honda S2000 models with a 2.2L engine, and 2000-2007 Honda S2000 models that have a 2.0L engine
K&N also supplies other models for Honda. For more information about available K&N replacement air filters, and intakes for your Honda, please check out the links below
