Honda CR-V & Element 2WD & 4WD Element & CR-V
2010 Honda CRV will not shift out of Park. Will not start. Brake switch is good.
Old Apr 1, 2017 | 02:01 PM
foolotto's Avatar
Default 2010 Honda CRV will not shift out of Park. Will not start. Brake switch is good.
My wife's 2010 CRV is stuck in Park. I can get it into Neutral (using the key in the console slot). Checked virtually every fuse - all good. Checked the brake switch (it was good and brake lights function) but replaced it anyway. Still no luck. When I turn the ignition key on the dashboard lights flicker and act weird. Now this is the strangest part - even though the shifter may be in Park I jacked up the front end and could spin both tires. So it sounds like some cable is not engaging but I have no idea where to check! Any advice? Thanks - Tim
Joetxstate
Mar 4, 2020 05:37 AM
fixmyhonda20
Apr 2, 2013 02:35 PM
courtney42
10
Jul 10, 2009 06:13 AM
ajbabygirl02
Jun 12, 2008 03:54 PM
DC5_lov3r
14
Aug 7, 2007 01:24 PM
