B20vtec which HG to use?
Old Apr 1, 2017 | 10:25 AM
trinib20's Avatar
Default B20vtec which HG to use?
It has been a while
I have already used the search and there are lots of mixed reviews
I am building a NA b20vtec 10-11cr nothing fancy
It do not come down to price but what works properly
Head gasket options
OEM b20b HG
cometic b20vtec
GE b20vtec
thanks
Old Apr 1, 2017 | 10:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B20vtec which HG to use?
I would use the OEM B20B head gasket.
Old Apr 1, 2017 | 11:14 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Golden Eagle HGs have the dowel holes opened up for all head and block combos AFAIK.
Old Apr 2, 2017 | 10:17 AM
trinib20's Avatar
thanks for the assistance
Old Apr 2, 2017 | 07:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I have made it a habit over the years to open up the holes on the opposite side of the cylinder head so that OE dowels will fit in either a straight VTEC or LS/VTEC application and still use the stock head gasket. This causes no problems with the cylinder head for future use on a VTEC block and eliminates the problems with stepped dowels and inconsistent aftermarket head gasket stampings.
Old Apr 4, 2017 | 04:47 PM
trinib20's Avatar
^ saw some did that in the past
I see no one mentioned Cometic .. Issues ?
Old Apr 4, 2017 | 09:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Cometic is a fine product as well... just don't get caught up in the hype of the hybrid gaskets. If you buy a NON-VTEC Cometic head gasket for your bore size, it will work just fine.
Old Apr 4, 2017 | 11:44 PM
KiNGDEE206's Avatar
adding to OP
using nonvtec gasket = remove O rings IS A MUST (idk if easy or not but something you MUST do)
using GE vtec gasket = PLUG AND PLAY
*cometic hg* i read its a hit or miss on working and not working
cometic is $80 hg shipped
honda oem is $100
GE is $140-175 shipped
Im doing a b20vtec myself
im personally doing ge kit just cause plug and play and because DDTECH@honda-tech and i believe allmotor @honda-tech suggests it too!
found that on one of the ht forums
The problem with using the non-vtec gaskets is they cover up one of the water jacket ports to the VTEC heads which can cause temperature differences from one side of the head to the other and possibly cause the head gasket to blow or even warp the head. I only use Golden Eagle gaskets that's just me.
Old Apr 5, 2017 | 03:28 PM
trinib20's Avatar
thanks
will be going with the GE
thanks for the feed back
Old Apr 22, 2017 | 12:34 AM
bks84's Avatar
Loved
I do exactly this. I bought a 14mm bit, and when i build one of these, i take the head and bit to a machine shop and have them do it for me. i dont have a drill press at home, plus i typically have the heads looked at before I use em too.
In short:
Move dowel pin holes on VTEC head to match the block.
OEM B20 headgasket
OEM Dowel Pins
Old Apr 24, 2017 | 07:42 AM
solorex's Avatar
I just bought a GE headgasket. Perhaps it's older stock but it was simply an OEM headgasket (still in the OEM packaging) just had the dowel holes machined larger FYI.
Old Apr 24, 2017 | 05:48 PM
DumpdEJ6's Avatar
I like the tuna here
I think they use the OEM gasket, that's what came in my kit.
Old May 22, 2018 | 02:21 PM
strategy400's Avatar
The bad cylinder(s) will be pretty apparent (clean).
Get a precision straightedge and check the cylinder sleeves at the top of the block. They tend to get corrosion and leak. It will look like a coffee cup ring stain. If you lay the straightedge over the corrosion with a light behind and see any daylight you're best off to have the block resurfaced. This means stripping the block down to, that's right, the block. Every single nut and bolt. Pretty much the same as a rebuild. If the engine is running good other than the head gasket it's worth it. You'll need a few torque wrenches and a ring compressor.
The head can be resurfaced with everything still installed.
b20forlife
Aug 7, 2009 01:45 PM
blackcrx16
Mar 18, 2008 03:24 PM
killacam661
Sep 11, 2007 01:57 PM
dansred2000si
Mar 10, 2007 10:55 AM
sickerhatch
Apr 16, 2005 10:14 AM
