I may be in over my head with this build
Okay, so I almost have my LSVtec motor completely built, working on finding a transmission for it now. Was planning on putting it into my EG sedan but then found a great deal on a 91 CRX Dx. Only problem here is I need to convert from DPFI to MPFI, add vtec and iab wires, I would like to wire tuck while im dealing with all that, I also need to do whatever wiring conversion is needed for auto to manual. All the guides I have found are so old that the pictures dont load and this is also my first shell to car build and first swap ever so go easy on me with the "google it". Thanks in advance for any help, really just want to know if you know of any good guides and or know what order i should be working on all the changes on.
You don't need pics just read and folllow directions , get a pin out , solder gun , hear shrink , and go to town it seems intimidating but it's really simple , you only wiring in 4 wires on the injectors (2 injectors and two grounds ) the other injectors go to the existing 2 injector wires , you repin the dizzy and add two wires there , vtec is 3 wires , you have to extend the IAT WIRES and whatever obd alt you use you have to wire in that plug , really nothing else to it , I'd assume you have a jumper for the ecu , and if you want you can buy a jumper for t the dizzy knocking you down to just injectors and vtec and 02 , if you can build a lsv you can wire a dpfi to mpfi
if you're not confident in this then do one thing at a time. just doing a swap is likely to require some troubleshooting when you try firing it up, and speaking from experience you dont want to make things even more confusing just yet
maybe get a manual because i dont really know how much extra wiring is under the dash for auto(correct me if im wrong) and for the harness i think you can buy a ef si harness and you should be butter. easier that a mpfi conversion.
... and easy.
google is your friend.
No-Gi
May 21, 2005 05:07 PM
