B18c1 hybrid hatch Dyno results
I dynoed my car today, just finished the motor swap a couple days ago, have a:
2001gsr swap, skunk2 Intake manifold, skunk2 obd1 ecu, aem intake, si b-pipe and cat, stock muffler.
i got 144.3 hp and 114.3 torque in a 3rd gear pull till 8,000rpms
you guys think this is good or about right?, i was expecting alittle more maybe like 160, maybe i need to get a vafc and tune the ecu a bit its running rich.
edit: will have the chart up tomorrow, just gotta scan it.
[Modified by Civ-JDM, 6:38 AM 11/10/2002]
With an AEM CAI, DC 4-2-1, Thermal catback, gutted cat, Skunk2 IM, ZEX flywheel and a 1st gen B16 ECU my B18C1 made 165.9/121.7 revving to 8000rpm.
exhaust may be ur downfall...
when i had my stock CX exhaust on my EK-GSR... it made
142hp... with my new thermal i made 154hp... forgot the tq #'s
the damn cx exhaust is a cork.
i might venture onto a 1st gen b16 ecu too? how did it run with the ecu?
The car runs pretty good with the ecu. The only bad thing was the VTEC engagement being set at 5200. With that setting my torque dropped from 115ft/lbs @ 4800rpm to 105ft/lbs @ 5200 then shot up to 120ft/lbs at 5300. I have the engagement set at 4800 now via my AFC and it's smooth like butta.
Even now with 7.8psi of boost it still runs pretty good. A good exhaust could be whats holding you back. Good luck!
I got mine done on a Mustang 4 dyno at Speednation in PA, which is more accurate than the dyno jets, but reads about 10% lower than the dyno jets. with my cam gears tuned and stuff i made like 148 whp which if you boost it up to the dyno which you guys ran on is like 160 - 165 whp. with my dyno plotted against type r's with boltons I am making about an average of 7, with a peak of 12 more horse power between 3 and 7 grand. I had about 4 hp less above that. over all, i am happy, and my car screams, especially when i hit the bottle
Most of the people at this dyno day say even this dyno was off. A few boosted people claimed that they made 10 hp more with the same mods on a different dyno.
not bad for a stock gsr, basically. i have a 99 b16 in an ek and made 158.6 at the wheels with type r cams, aem intake, jdm header, apexi exhaust, obd1 harness and computer.............decent for a b16
I think ur exhaust is killing you.
I hit 161whp/123tq:
b18c1
injen cai
jg header (2.5''collector)
highflow cat
crushbent
2.5'' piping
thermal straight thru muffler
-Rod
[Modified by RK, 4:08 PM 11/12/2002]
I hit 161whp/123tq:
b18c1
injen cai
highflow cat
crushbent
2.5'' pipingthermal straight thru muffler
-Rod
1995 B18c1, Stock internals
Skunk2 Cam gears
Greddy PE exhaust
DC 4to1 Headers
K&n intake
FPR
Made 160WHP at Import Builders....on a hot day...
Skunk2 Cam gears
Greddy PE exhaust
DC 4to1 Headers
K&n intake
FPR
hmm...im Silver EG's roomate,i have ....
00 gsr
dc type r header
skunk2 IM
spoon flywheel
kenji progam
iceman cai
tanabe racing medalion w\no cat
i did 169hp-125tq
[Modified by ArmyGreen EG, 12:46 AM 11/16/2002]
00 gsr
dc type r header
skunk2 IM
spoon flywheel
kenji progam
iceman cai
i did 169hp-125tq
yes that also,
at Secrete Services Here In Tampa (Vaportrail) there was a type R dyno day...thats when we went and it was 100 degrees in the shop (seriously)
chris
chris
