Del Sol climate control wiring/pin diagram
Old Mar 29, 2017 | 08:30 PM
donjuma's Avatar
Icon7 Del Sol climate control wiring/pin diagram
Hey all!
I've been searching around for a few days now and I just can't seem to find an input/output pin diagram for the AC/Heating control unit in my Del Sol.
I'm trying to remove the whole unit and replace it with an Arduino so I can control it from a touchscreen, but I just can't make any sense of the wiring.
I removed the heating control unit and found that the wire harness splits into two connections on the back of the unit. One connector has 6 wires and the other has 12.
Does anyone have a diagram of what each wire connects to? I would like to recreate this system using the pins on my Arduino.
Any help at all would be much appreciated.
Thanks
This is the wire harness connecting to the back of the unit.
Old Mar 30, 2017 | 10:39 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: Del Sol climate control wiring/pin diagram
Honda-tech doesn't host free Factory Service Manuals but other sites do.
You can get the I/O information from the FSM. However, you may need to buy the Helms electronics manual.
Helm Incorporated: Search Results
You can also buy the regular FSM from Helminc
MiniTrev
Jan 4, 2013 01:44 PM
acidburn2k2
Jan 2, 2006 11:40 AM
