Boost or not to boost (brakes)
Old Mar 29, 2017 | 10:31 AM
crabb8's Avatar
Default Boost or not to boost (brakes)
I am installing rear discs on my 93 Del Sol and was wondering what if I took off booster and ran 2 masters as in a race car with a balance bar? What would be good? What would be bad? Defiantly would clean up the engine compartment. Other ideas or thoughts?
Old Mar 29, 2017 | 11:01 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: Boost or not to boost (brakes)
Do it. xtrac1 doin' it.
https://honda-tech.com/forums/genera.../#post50030740
Old Mar 29, 2017 | 03:10 PM
crabb8's Avatar
What size masters did you use front/back and by who? I most likely would prefer to hang in stead of floor.
Old Mar 30, 2017 | 07:48 AM
CX-Adam's Avatar
talks to himself
Community Builder
I didn't do it. I said xtrac1 is doing it. You use the same size master for both and the balance bar adjusts the bias. MC size would depend on pedal ratio, brake piston size, and brake piston travel (essentially a volume calc and force inpout/output calc).
You can set them up however you want based on preference and the depths of your pockets/fabrication skills.
The brake system I designed/redesigned for my formula SAE team had the masters below the pedals. Best picture I could find:
Old Mar 30, 2017 | 02:47 PM
crabb8's Avatar
Got it
Jdmsoles
Suspension & Brakes
May 17, 2009 09:04 PM
Junkie
Dec 22, 2007 10:29 PM
SpeedoKing
Oct 24, 2007 11:25 AM
vizeta
Aug 17, 2004 08:00 AM
Lip
Oct 7, 2003 04:44 AM
