Crank pulley help
Hey guys im doing an h2b swap on my da. Right now the motor is in but had to be set in without the crank pulley on. Im thinking im going to have cut the frame a bit to fit it but before i do that does anyone recommend a different pulley or any under drive pulleys or even a single drive pulley? Anything to make it easier to fit. I still have the whole timing set up intact with the motor and really dont plan on tearing it down unless needed. I am also running no ac or ps since theres no room for it.
Can you loosen the motor mounts and lower the driver side of the engine down? Or is there just not enough room between the engine and frame to fit the pulley at all?
ive tried multiple ways. Lowered the engine and it just wont fit. If i have to ill chop a bit off to fit and weld some angle iron there. Ive already beat my frame in to where everything but that fits. Im just exploring options.
black94lude
Sep 17, 2009 12:29 PM
thehatchninja
Jul 13, 2008 10:04 PM
