Suggestions Needed: No power to ecu after mpfi swap
Old Mar 24, 2017 | 06:54 PM
effer's Avatar
Default Suggestions Needed: No power to ecu after mpfi swap
I have a 90 Honda Civic STD, I recently swapped my obdo dpfi to an obdo mpfi, I followed all the instructions I copied off others who have successfully done swap but now I have no power to ecu (no light coming on when I turn key to on position and no fuel pump or spark at plugs). I have checked and replaced all fuses.
someone please help before I burn this car to the ground
Old Apr 8, 2017 | 08:33 PM
ratchetEDsedan's Avatar
Default re: Suggestions Needed: No power to ecu after mpfi swap
Checked ground strap/terminal issues? It always seems like the simple **** happens to me. Turn running lights on and fool around with the cables, see if they flash at all.
Old Apr 11, 2017 | 07:34 AM
motoxxxman's Avatar
injectors, coil, ecu, and fuel pump are all powered by the main relay. check the main relay, and all wiring related to the main relay
Old Jul 15, 2017 | 04:24 AM
effer's Avatar
ok so it has been a long process of conversion but she is running Nice, however now my AC is not working and this is something I am interested in having for these 104 degree days. Does anyone have any idea how to get AC working again after the MPFI swap
Old Jul 15, 2017 | 04:37 AM
effer's Avatar
Default no ac after mpfi swap
does anyone have any clue how to get AC working again after a DPFI to MPFI swap.... sort of a big deal in 104 degree weather.
jhota
Sep 14, 2006 05:03 PM
2 0 3
Jul 30, 2006 05:36 PM
FunIntegras
Sep 1, 2005 08:04 AM
PGT Driver
Jan 15, 2005 11:09 AM
brnojoke
Jul 30, 2003 09:34 AM
