Throttle body shaft seals ????
Old Mar 23, 2017 | 06:30 PM
got_no_sol's Avatar
Default Throttle body shaft seals ????
I've found out I have a leaking seal behind the throttle cable mount is this a replaceable seal ? Or does anyone have a fix for this ??
Old Mar 23, 2017 | 07:33 PM
bbarbulo's Avatar
Default Re: Throttle body shaft seals ????
never seen this. what makes you think the throttle body shaft is leaking? is there any play in the throttle shaft itself?
Old Mar 24, 2017 | 03:23 AM
got_no_sol's Avatar
We were checking for vacume leaks , it's leaking right behind the spring a small shot of starting fluid in the spring and idle goes crazy for a second
Old Mar 24, 2017 | 11:34 AM
4drEF's Avatar
Keyboard Humorist
They all leak to some degree as the bushing wear. It's common and there is always leak to some degree.
I've heard of this as a particularly notable problem on certain after market TBs on boosted cars.
Throttle body tune-up kits have these parts and more.
Old Mar 24, 2017 | 02:22 PM
94eg!'s Avatar
#1 Super Guy
Loved
You could try removing the throttle bracket and covering the gap with silicone grease as a quick fix.
Old Mar 25, 2017 | 12:33 PM
bbarbulo's Avatar
this isn't the sort of thing I would focus on. there can't be too much air getting through there unless you have play in the throttle shaft.
Old Mar 27, 2017 | 04:41 AM
v4lu3s's Avatar
RTFM
If there are no other leaks and he has idle problems then I would say this IS something to focus on. i have not had this problem even on a throttle body with 300k miles.
Old Mar 27, 2017 | 05:30 AM
94eg!'s Avatar
#1 Super Guy
Loved
I have a weird cold-start idling issue where when I first start the car, idle jumps to 2200rpm and then settles at about 1800-2000 (even when it's 80* outside). Once it starts to warm up, the ECU has no trouble making a steady 750, but this always bugged me. I'm completely out of things to check, and re-check. Perhaps I'm having this issue as well. I'll have to check into it this week.
Greyout
K Series
Dec 2, 2015 05:00 PM
carlos8
Dec 22, 2013 01:07 PM
spermdoggy
Jun 4, 2012 06:58 AM
Des9255
Oct 24, 2005 09:58 PM
ttboy
Feb 18, 2002 12:04 PM
