EM1 rocker panels rusting
I have a 2000 civic si that is rusting out. I'm debating on replacing the rockers and wheel arches but cannot find any. I have found them for 4 doors and older civics but not 96-00 coupes. does anyone know where to get them? or am I better off trying to find a rust free shell? I assume finding a em1 shell could prove to be difficult. Thanks
If you can find a rust free shell I would go that route. It's easier and cheaper in the long run. It doesn't necessarily need to be an Si shell either, an EX shell will be exactly the same and much easier to find.
This is the issue, I live in vermont so pretty much everything is junk or been crushed. I don't really want to travel half way across the country for a shell
Go with what the guy above said, you can swap everything you have over to any 96-00 coupe shell unless you want the 99-00 front end, then buy that era correct or do the front end swap. Problem solved. Another tip, go on a bunch of Facebook for sale sites around your era, could find some better results.
jdmef-9
May 15, 2007 08:26 PM
JdmEg6Hybrid
May 12, 2005 04:36 PM
