94 Accord EX vtec
Well, you have to consider the entire system. If u have a high flow pump, fuel pressure regulator, and a tuned ecu, then you would want the injectors to be as good or better than the potential output of the pump/ regulator. Simple bolt ons, however will likely have no effect on your power of your ecu isn't tuned to compensate.
