can i convert a manual vertial bandsaw to be semi auto?
Old Mar 20, 2017 | 04:55 PM
RACEPAK's Avatar
Default can i convert a manual vertial bandsaw to be semi auto?
hi guys,
i just got a new bandsaw, and i was wondering if i can convert it to semi auto, is there a company that makes kits? or maby somone know where can i buy a cheap bandsaw piston ?
thanks alot, here are some pics of the saw,
Old Mar 22, 2017 | 11:50 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: can i convert a manual vertial bandsaw to be semi auto?
Yes, just purchase a "hydraulic downfeed cylinder" from one of many souces on the Internet. Pneumatics tend to be a bit more "choppy" on the descent and the hydraulic ones are much smoother both up and down. You can also just get a double acting cylinder, tubing, and a needle valve and make your own. I am sure there are guides on this subject matter out there online, but fabrication will most likely be involved. It will go in the same spot your springs are now and work out nicely. Just be sure to measure before you purchase anything and try to get the biggest one you can (within reason). I hope this helps, good luck!
Fabolous.
Other Make Vehicles
10
Oct 20, 2009 03:59 AM
LiquidIroc
Jan 31, 2005 03:23 PM
jdm92accord
Feb 7, 2002 11:22 PM
AzN_Flava
Nov 15, 2001 03:56 PM
