[Possible?] Electrical Issues.
Old Mar 19, 2017 | 09:25 PM
Ray Satomi's Avatar
Default [Possible?] Electrical Issues.
I have a '90 STD hatch, and when I have my headlights and turn signals on at the same time all the lights dim. Same goes for when brake lights are on, all of the lights will dim slightly but return immediately if I remove the other loads. Is this normal for these cars, or should I start checking the ELD and alternator? I haven't had any problems with it starting, and the battery seems to be charging normally. What voltage should I be seeing in the system, and how far is it 'acceptable' for it to drop with everything on (so i can test it)?
Old Mar 20, 2017 | 06:03 AM
Slade Exulis's Avatar
Default Re: [Possible?] Electrical Issues.
I would check/clean your grounds.
CaseyB
Nov 27, 2012 06:30 PM
justinwebb
Mar 9, 2009 11:45 AM
Puro Zacatecas
Nov 27, 2008 05:33 PM
Inline6 Silvia
Nov 12, 2006 11:19 PM
KevinT707
Feb 6, 2004 03:41 PM
