Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Honda Civic runs rough when accelerating
Old Mar 18, 2017 | 10:17 PM
Caventi's Avatar
Default 2005 Honda Civic runs rough when accelerating
My Honda only runs rough when it's warm outside, like over 70 F and only when I first start it accelerate it in gear. Recently it threw a couple misfire codes and I changed the spark plugs which helped but I feel like they fouled quicker than they should have since I changed them about 1 year prior. I've also changed the fuel filter/ pump and an oxygen sensor. I was just wondering what could cause this weird problem. Thanks.
Old Mar 19, 2017 | 07:35 PM
bbarbulo's Avatar
Default Re: 2005 Honda Civic runs rough when accelerating
incorrect engine coolant temp or intake air temp reading will do this too. check the readings with and OBDII scanner
Old Mar 20, 2017 | 08:55 AM
NDNV's Avatar
What are your codes?
Check the EGR valve for failure and clogged ports with carbon.
Old Mar 20, 2017 | 09:38 AM
Caventi's Avatar
I just got a code yesterday and it was a cylinder 1 misfire. I pulled out the ignition coil to switch it with cylinder 4 to see if the ignition coil was the problem and there was a little bit of oil on the outside of the coil. I'll check out the EGR valve when I get a chance.
Old Mar 21, 2017 | 03:50 AM
NDNV's Avatar
Use only OEM NGK spark plugs.
Old Mar 28, 2017 | 07:09 PM
Caventi's Avatar
I only use NGK spark plugs, I cleaned the EGR and the MAP sensor but to no avail. I can't figure it out.
Old Mar 29, 2017 | 12:14 AM
Justin Ripley's Avatar
oil on coil would say the valve cover gasket...the 4 o rings going around the plugs...are leaking. This could foul plugs...
MIKHAN
Aug 26, 2017 03:56 AM
05hondagirl
Sep 23, 2013 08:46 AM
Noel Yeow
Jul 26, 2012 10:16 PM
sethmoman
12
Dec 28, 2011 10:00 PM
hondaowner
Apr 6, 2004 04:42 AM
