Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Acura TSX 2004 Navi - Radio Power Issue
Old Mar 17, 2017 | 12:57 PM
Christoph Choe's Avatar
Default Acura TSX 2004 Navi - Radio Power Issue
Hello,
I am currently having an issue with my radio, it will not turn on. The display for the time is also non-existent. Below are some methods I have tried:
1) Checked ALL fuses, none blown out. Radio still not working.
2) Held the CD/AUX button to apparently reset? Nothing happens.
3) Removed battery cables. Temporarily, worked initially. Afterwards, back to no power. I don't know if it has any relevance but on start-up after the reset the time kept flashing in and out. The second time I start my car (and every other time after), zero power to the radio. I can't even hear the cd disc changing.
The PCB was swapped 6 years ago, wondering if that's the issue again now. I wasn't covered under the warranty at the time so I had to pay around 2 thousand to get it fixed, trying to avoid paying for that again. Also, my Navi works perfectly fine, the display time is gone and the radio has zero power. Can anyone give me any clarity on this matter?
Old Mar 17, 2017 | 12:59 PM
kb8thekid's Avatar
Default Re: Acura TSX 2004 Navi - Radio Power Issue
check out the tsxclub forums, they have a little more insight on this, mine was doing the same thing, but it turned out to be the DVD player in the trunk went bad
Old Mar 17, 2017 | 01:14 PM
Ah, the DVD player? Interesting, will check that out. Thank you!
dmw.604
Acura TL, RL & ZDX
Jan 29, 2016 02:10 PM
swennybear23
Nov 19, 2014 05:08 AM
CTyson
Dec 27, 2011 11:19 AM
starbai
Audio / Security / Video
Oct 7, 2008 03:10 PM
