question on HID
Old Nov 9, 2002 | 05:55 PM
ptsiu's Avatar
Default question on HID
I'm a newbie to HID...wondering if I can use the 94 and up Integra housing with HID kit or any other alternative? Which kit is the best setup?
Old Nov 9, 2002 | 07:32 PM
MTK Kommander's Avatar
Default Re: question on HID (ptsiu)
well..do you have an integra? or are you going to throw the integra projector into another housing..
if u have an integra, just get a 9006 HID kit with D2S bulbs. also, avoid letting a salesman try to sell you 5000K 6000K 7000K 8000K or 9000K HID kits.. 4300K is the right color temp.
if you're going to do a projector swap, dont waste your time with halogen housings.. just go on ebay and get a set of audi, bmw, s2000, or anything that uses projectors for OEM HID.. and just use those.. integra projectors with HID arent very impressive.
Old Nov 9, 2002 | 09:10 PM
ptsiu's Avatar
Default Re: question on HID (MTK Kommander)
I have an integra.....so you are saying HID kit doesn't work pretty well with factory housing right? what should I get to make like those beamer?
[Modified by ptsiu, 6:10 AM 11/10/2002]
Old Nov 9, 2002 | 09:19 PM
they work better than halogen.. but to make it like a bmw..you gotta get an OEM HID projector and swap it out with your integra one..its a tough project..but worth it.
Old Nov 9, 2002 | 09:22 PM
ptsiu's Avatar
thx for your advice and I really appreciate your fast response.....but I have no idea how to do a swap......you mean to get a housing for HID? but integra doesn't have that aftermarket projector housing.....really have no idea how to do it
Old Nov 9, 2002 | 09:28 PM
u gotta take the housing apart.. take the projector out..and put the new one in.. (easier said than done)
Old Nov 9, 2002 | 10:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I have friends w/ HID in their Integras.... the light output compared to halogen is just awesome, even the HID retrofits. Beware of stuff on eBay, ALOT oh HID headlights on there are most likely stolen
Old Nov 10, 2002 | 01:56 AM
IntEGNYC's Avatar
I have a 9000k HID kit with hella balasts on my 95 Teg. They arent as impressive as those found on an s2000 or other cars that come with the HID lights, but they are certainly a step up from the Stock halogens.
I wouldnt go back anymore.
Old Nov 10, 2002 | 02:12 AM
:jdmshmaydm:'s Avatar
Default Re: question on HID (IntEGNYC)
Yikes! 9000k...
Old Nov 10, 2002 | 03:03 AM
NrG's Avatar
NrG
Default Re: question on HID (Gatecrasher18AF)
back in the days when i was looking for a car, i was going to pick up a teg, and get some acura CL HID and put them in the teg, i hear they fit perfect.. with slight modification
my dad's friend had a chopped CL in his junk yard.. he was gonna give them to me for like 50 bucks..
Old Nov 10, 2002 | 03:20 AM
ptsiu's Avatar
Default Re: question on HID (NrG)
I found a pretty good deal on the 2002 A4 xenon projector. does that work for swap? and what HID i should get?
Old Nov 10, 2002 | 03:54 AM
the reason they arent impressive is because they are 9000K.. the color temp is so high that the lumens are near halogen output.. ive seen plenty of these 9000K kits on RSX's around here..they have kinda like a pinkish voliet blue output, and the ground isnt lit up at all..
Old Nov 10, 2002 | 07:22 AM
Community Builder
CL's use D2R bulbs, you need D2S for projectors.
Old Nov 10, 2002 | 04:50 PM
that would work perfectly for the swap..
Old Nov 10, 2002 | 08:19 PM
ptsiu's Avatar
that' too bad....I found out the seller only got a single, not a pair......how about BMW X5?
Old Nov 12, 2002 | 12:08 PM
ptsiu's Avatar
I'm still wondering which projector and HID kit is the best for swapping integra headlight and the best combination....here are some choices:
PROJECTOR:
BMW X5
Audi A6, A4, S4
HID KIT:
Audi S4, TT , A6
PLEASE ADVICE!!!
Old Nov 12, 2002 | 12:10 PM
any OEM HID projector will be good.. you could even use the Hella 60mm or the 90mm.. those are aftermarket HID projectors..they work great..
Old Nov 12, 2002 | 12:12 PM
ptsiu's Avatar
so how about the HID kit? does it matter? coz' I couldn't find a complete set of hid kit with projector....so have to buy it separately....PLEASE ADVICE
Old Nov 12, 2002 | 12:39 PM
it has to be an OEM D2S bulb.. it cant be a halogen fitted bulb..so if it says something like 9006, 9004, H4, or any of those fitments..it wont work.
Old Nov 14, 2002 | 07:53 PM
ptsiu's Avatar
wondering anyone knows the diameter of inetgra's projector.
Old Nov 14, 2002 | 08:11 PM
integ projectors are bigger than OEM HID ones.
Old Nov 14, 2002 | 08:57 PM
ptsiu's Avatar
so is there any projector I can put in integra housing without make the hole bigger?coz' I'm trying to save as much work as I can to do the headlight swap.
Old Nov 14, 2002 | 09:19 PM
you arent making any holes.. you just have to cut the integ projectors mounting bracket off and JB weld it to the OEM HID ones then bolt them back in.
Old Nov 14, 2002 | 09:55 PM
ptsiu's Avatar
oh.....not even making it bigger or something?....oh that's great...I thought due to the projector size....I have to modify the size of a hole on the headlight to make it fit. Would that be better using honda projector like those in S2000 instead of using BMW's and Audi's so that I don't need to do much more work? coz' I'm so worry losing the aiming function on my headlight. Does that matter?
Old Nov 14, 2002 | 10:09 PM
ptsiu's Avatar
something about the electrical part....I need a harness to plug into my original power source and connect it to the ballast right? where can I get that?
