Spoon Caliper Clearance
Old Mar 14, 2017 | 06:40 AM
b18_crx's Avatar
Default Spoon Caliper Clearance
Before I get flamed for not using the search function, I did. Trying to see if a concave 15x8 +27 TE-37 will clear spoon twin blocks. Im thinking im going to have to use a 8mm spacer but just asking to see if anyone has a definite answer. The Car is a 98 ITR with the 36mm ITR hubs.
Old Mar 14, 2017 | 07:26 AM
silver_gs-R's Avatar
Default Re: Spoon Caliper Clearance
yes you will be fine, a stock 15`ITR wheel clears Spoon Twinblock with a 5mm Spacer. I run 15x8 +32 TE37 over Spoon Monoblock with a 3mm spacer.
Old Mar 14, 2017 | 07:31 AM
itr#1334's Avatar
Oem 15's clear with no spacer.
Old Mar 14, 2017 | 07:36 AM
b18_crx's Avatar
twin blocks do, monoblocks don't from what I understand
Old Mar 14, 2017 | 08:52 AM
dave7's Avatar
10 Year Member
Right, and you have twin blocks so you should be fine with your setup.
Old Mar 14, 2017 | 10:23 AM
JDM CTR '00's Avatar
My twin block Spoon calipers clear my 15x8 +32 TE37 SL's with 5 Lug (EK9 No spacers).
b18_crx
Mar 14, 2017 05:32 PM
JDM PRO
Aug 18, 2005 11:22 AM
