What is this part?
Old Mar 12, 2017 | 08:31 PM
ZombieSalus's Avatar
Default What is this part?
There's a hole the size of a pencil in that hard plastic piece causing a vacuum leak.
What the hell is that so I can replaced it?
Nobody around here seems to know.
Old Mar 13, 2017 | 05:54 AM
Default Re: What is this part?
It's a 2003 Honda Civic Si ep3 if that helps.
Old Mar 13, 2017 | 07:09 AM
NDNV's Avatar
I guess that would be your PCV valve.
Old Mar 13, 2017 | 03:57 PM
bbarbulo's Avatar
naw, pcv is next to the alternator on the other side of the engine.
haven't been able to locate that part yet though, I've found the housing it goes into, but not that part.
Old Mar 13, 2017 | 05:44 PM
toyomatt84's Avatar
Sanji
Air control valve.
Old Mar 13, 2017 | 08:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Fast idle thermal air control switch. Allows additional air to be injected into the intake manifold until the engine warms up to above 140 degrees F. Once this threshold is reached, the valve closes the air path and the idle drops down to normal.
The unit you have pictured is broken... there is normally a fitting facing the drivers fender that connects a hose to the intake pipe where it draws fresh filtered air before the T/B.
Old Mar 14, 2017 | 06:31 PM
Thank you JR!
I actually just got an RSX yesterday and saw the intact part so I know the nipple on the side going to the intake but still had no clue what it was called.
Kodi Dubea
Apr 19, 2018 03:43 PM
roninzane
Jan 25, 2007 06:40 PM
EFnerd
Jul 19, 2006 11:00 AM
SupraRXZ
Jan 23, 2006 04:31 PM
Gsr_Rob
Jan 25, 2005 06:09 AM
