D-Series Mini Log Mani + RC SL9 550 Injectors
Old Mar 12, 2017 | 02:37 PM
60002nv's Avatar
Default D-Series Mini Log Mani + RC SL9 550 Injectors
For Sale: D-Series SLS Mini Log manifold. Approximately 15,000 miles of use on this manifold before parting the car. T3 flange, 38 mm external WG. Small dent/nick on the #4 primary. See photo for detail.
Asking $200 shipped to contiguous 48, reasonable offers considered.
For sale: RC SL9 550 injectors. Used in the same build, approximately 15,000 miles of use. It has only seen premium gasoline fuel only if that makes a difference to you. Polished fuel rail included, I believe this is a Honda OE Y8 fuel rail, but I can’t remember. Asking $200 shipped to contiguous 48.
Located in Southeast Michigan. Please contact via PM and we can take it to email or text message where appropriate.
Last edited by 60002nv; Mar 28, 2017 at 04:12 AM. Reason: added "to contiguous 48" to shipping note
Old Mar 21, 2017 | 04:55 AM
60002nv's Avatar
Default Re: D-Series Mini Log Mani + RC SL9 550 Injectors
ttt
Old Mar 24, 2017 | 10:43 AM
thewood1988's Avatar
Do you need a resistor box to run these?
Old Mar 26, 2017 | 04:27 PM
Solarflare's Avatar
That manifold AC and PS compatible?
Old Mar 28, 2017 | 03:52 AM
60002nv's Avatar
It is not AC & PS compatible. According to SLS it is P/S compatible. This was installed in a CX w/o A/C w/o PS.
Old Mar 28, 2017 | 04:00 AM
60002nv's Avatar
These are saturated, no resistor box needed. Plug and play for OBD I injector harness. I can send photos of the injector connector to interested parties to confirm.
For OBD II harness you either need an injector jumper cable set or you need to complete a cut/paste operation by removing OBD II injector connector and replace with OBD I injector connector. Some people dremel out the feature in the OBD I injector connector to make it fit with an OBD II harness, but I would advise against this. You lose the rubber seal to prevent water ingress
Old Apr 24, 2017 | 08:26 AM
60002nv's Avatar
ttt, send your reasonable offers. Worst I can say is no thanks
Boogymonster95
May 5, 2014 02:15 PM
13g-crx
Apr 13, 2014 02:26 PM
T-Charged-Civic
May 26, 2006 05:42 PM
