Orientation of the snap-ring for the wheel bearing
Old Mar 10, 2017 | 03:40 PM
petr0lb0mb's Avatar
Default Orientation of the snap-ring for the wheel bearing
Logic tells me that the machined flat surface of the snap-ring should face away from the bearing, but when I took it apart, it was the other way around (flat edge against bearing). Not sure if it's that way from the factory. Just wondering if anyone knows which way the factory installs them.
The picture is how I think it should go, but not how it was.
Old Mar 10, 2017 | 10:04 PM
petr0lb0mb's Avatar
Default Re: Orientation of the snap-ring for the wheel bearing
Set the snapring aside waiting for a reply to this post and proceeded to put the hub back on without it. Welp, that mistake will cost me $80 for a new bearing. Haha!
Old Mar 10, 2017 | 10:07 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I've not done any wheel bearings so I am definitely no authority, however, I would put it back on the way I found it.
Old Mar 11, 2017 | 12:08 AM
petr0lb0mb's Avatar
Barring any solid facts, that's what I'll do.
Old Mar 11, 2017 | 03:48 AM
94EG8's Avatar
Seagull Management
Honestly it doesn't matter which way you put it in.
Old Mar 11, 2017 | 06:03 AM
mk378's Avatar
I think that is just an artifact of how snap rings are manufactured (by stamping them out of a flat plate). There's no intentional "sidedness" to them, and it doesn't matter how you install. If you look at a flat washer closely you see the same thing.
Old Mar 11, 2017 | 06:17 AM
94EG8's Avatar
Seagull Management
^ exactly.
rexload
Jun 5, 2015 11:31 AM
RacerTim
Sep 10, 2010 05:44 PM
thunderboy
Mar 20, 2009 12:15 PM
petergriffen
Aug 11, 2006 08:44 PM
ViZ
Feb 11, 2005 07:52 PM
