How do i stop my axles from spinning?
Old Nov 9, 2002 | 05:03 PM
youngkow's Avatar
Default How do i stop my axles from spinning?
How do i do that so i can remove the axle nut? I got a motor that came with the sub frame, and there is no way i can take the nut off. Any ideas? Thanks in advance.
Old Nov 9, 2002 | 06:16 PM
tSuperbike69's Avatar
Default Re: How do i stop my axles from spinning? (youngkow)
put the car on the ground and in reverse, have a partner press on the brakes. Or the easiest way is Hit it with a Impact
Old Nov 9, 2002 | 07:57 PM
B18VtecEg's Avatar
in the rotor itself.....there are slots....not on the face....but on like the top.....if you stick a thick flat head screw driver in there....until it hits the caliper....and then put pressure on nut....it will come off everytime..
Old Nov 10, 2002 | 04:38 AM
youngkow's Avatar
Default Re: How do i stop my axles from spinning? (B18VtecEg)
Great idea! Thanks!
Old Nov 10, 2002 | 05:57 PM
Kataku2K3's Avatar
Just hold the brakes.. Normally if i'm using a breaker bar then I just leave the car on the ground to snap the spindle nuts loose.. If you got one an impact gun is really easy.. Have fun
Old Nov 11, 2002 | 08:27 AM
youngkow's Avatar
Default Re: How do i stop my axles from spinning? (JDMspecEG6)
Thanks, but the engine is not in a car, just bolted to the subframe.
Old Nov 11, 2002 | 12:35 PM
Cynical 1's Avatar
Impact!
Check the nut and see if the corner is bent into the groove on the spindle. If so, take a screwdriver and tap it out. It makes it come off a lot easier.
Impact!
nicky352
Jan 19, 2011 07:38 AM
obrienjoe_05
Sep 2, 2008 07:59 PM
makoto
Jun 17, 2008 01:50 PM
taking-back-sunday07
27
Feb 22, 2007 08:10 PM
jdmspoonitr
Nov 23, 2004 06:57 PM
