Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2008 Accord engine wont turn over, wont crank up
Old Mar 8, 2017 | 01:29 AM
steven253's Avatar
Icon5 2008 Accord engine wont turn over, wont crank up
hello im new on here and i need help. I have a 08 Accord 2.4L Automatic trans. I stopped for gas yesterday and it would not crank up. When i turn the key the green key light blinks once and i can here the starter click but the engine will not turn over. And also when I lock the doors with the key the horn does not beep when pressing the button twice. If anybody has any input I would greatly appreciate it. Thank you
Old Mar 8, 2017 | 08:44 PM
prodjay10's Avatar
Default Re: 2008 Accord engine wont turn over, wont crank up
Have someone give you a jump. If it works, probably a bad battery.
Old Mar 9, 2017 | 01:23 PM
steven253's Avatar
the starter was bad. I replaced it and it fired right up. Sucks you have to take the exhaust manifold off to get to the starter though. Thanks for your input
Old Jun 19, 2017 | 08:19 AM
stereobumps's Avatar
Yeah the starter is in a bad place on these not really an novice DIY job
Old Jan 10, 2026 | 06:55 PM
Jayl1980's Avatar
This is the factory security system stopping it from starting. This is a common issue and leaving many owners stranded. Ive heard u can jump a wire from the starter selionoid and start it without issue every time. I maybe doing this as well and running it thru firewall into passenger compartment and u push button and can start car as normal
Old Feb 11, 2026 | 01:48 PM
ZaneKaminski's Avatar
5 Year Member
As for the key issue, I believe the car won't beep if the hood is open (or the car thinks the hood is open). This is a little bit less obvious than the doors or trunk since you don't get an indication that the hood is open on the instrument cluster. So if you're still having this problem, try checking the security hood switch:
brokenbus
11
Mar 23, 2016 07:03 AM
dwkirch
Mar 12, 2016 03:00 PM
hondaon18's
Nov 12, 2012 06:13 PM
jwicecold
Jun 9, 2010 03:31 AM
Kyoto now
Jun 30, 2006 07:18 PM
