Ecu dizzy wire swap for power
Old Mar 7, 2017 | 11:12 AM
89ED's Avatar
Default Ecu dizzy wire swap for power
D15b2 mpfi pm6 ecu . I don't have power to my white igniter wire on the dizzy plug at none of the turns of the key. hopefully that makes sense. I do have continuity from the white igniter wire on the dizzy plug to the ecu. I opened the ecu and measured from the inside the ecu to the dizzy plug. I have constant 12v power to pin 17 on plug A. there is no wires to that pin. could I put wires to pins 15 & 17 on plug B which go to the ecu from the igniter wire on the dizzy to pin 17 on plug A?
danteisme
Audio / Security / Video
Sep 29, 2016 04:33 AM
95accordh22a
Mar 15, 2005 11:48 AM
kinvid22
Nov 8, 2003 10:18 AM
