Piece of ceramic fell into cylinder :(
Old Mar 5, 2017 | 08:41 PM
JayDMJ's Avatar
Default Piece of ceramic fell into cylinder :(
Piece of spark plug fell down into the block and sitting on top of piston. Really dont want to remove the head and was hoping i could just remove this nut if possible? Anyone know if And how this comes out? I remember my last gsr i was able to put a ratchet extension down the hole. Any help would be appreciated.
Old Mar 6, 2017 | 05:06 AM
tony_2018's Avatar
Fish Twig
Default Re: Piece of ceramic fell into cylinder :(
Remove the broken spark plug first, dab some grease on a chop stick and get it out.
Old Mar 6, 2017 | 05:45 AM
DumpdEJ6's Avatar
I like the tuna here
^^^ Good idea. Could also try rigging up a drinking straw attachment to a vacuum with tape if there are multiple small pieces.
Old Mar 6, 2017 | 07:39 AM
JayDMJ's Avatar
The spark plug has been removed, ill try the grease trick, but a chop stick wont fit, ill try it with a coat hanger.
Ive tried the straw and vacuum and didnt work.
Can that nut down there be removed? Do i need a special socket? I tried a 17mm and doesnt fit.
Old Mar 6, 2017 | 07:42 AM
tony_2018's Avatar
Fish Twig
That looks to be part of the spark plug
Old Mar 6, 2017 | 08:08 AM
JayDMJ's Avatar
I agree, but I cant get a socket around it. 16 mill and 17mm socket wont grab it. 18mm only fits down half way. i dont ever remember the hole being that small cause my last b18c i waas able to put a ratchet extension down there to to see where the piston head was as in tdc.
Old Mar 6, 2017 | 09:02 AM
JayDMJ's Avatar
That the sliver that fell in the hole all one piece, didnt break up
Old Mar 6, 2017 | 09:42 AM
JayDMJ's Avatar
Im going to put some loktite on the threads and thread it in wait and hopefully it removes the full spark plug and give me the bigger hole so i can stick a straw down there or chop stick with some secured double sided sticky tape.
Old Mar 6, 2017 | 11:33 AM
JayDMJ's Avatar
Note to self: make sure compression fitting comes out before putting spark plug in hole.... got the fitting out, now im sure i can get the piece out. Thank you everyone.
Old Mar 6, 2017 | 01:20 PM
tony_2018's Avatar
Fish Twig
I knew something was up....
Old Mar 7, 2017 | 02:43 PM
DumpdEJ6's Avatar
Yeah that threw me for a loop...I was like "I KNOW whatever is in there isn't supposed to be there...but he DID take the spark plug out. WTF?"
Old Mar 10, 2017 | 02:48 AM
b16a971's Avatar
Try the vacuum again but make sure that the cylinders valves are open
HeresOtis
Nov 27, 2017 02:49 PM
pityocamptes
Sep 10, 2015 09:55 PM
Whatislove
Honda Civic (2001 - 2005)
Nov 17, 2010 11:12 PM
Honissan
Jun 9, 2004 08:14 PM
B_CRUZ!
Feb 14, 2002 08:45 AM
