90 crx si build
so ive got a 90 crx si complete shell minus engine trans and engine harness, now ive help friends do swap and build turbo set ups blah blah blah and so on but ive recently moved to tennesse from ohio and now i got this 90 si and dont have anyone to help so hopefully someone can help me out here. So i got the 90crxSi rolling chasis a d16a6 block, picking up A d16z6 head distributor exhaust manifold wires plugs, timing belt, obd0-obd1 rywire and p28 and the crx tranny and z6 intake & crx mpfi intake, not sire what trim the tranny is but kno forsure its not a si, is from a 89 crx, but only one available around here locally hopefully a dx, but so i kno i have everything for my build to get running other than d16a6 stock engine harness, now im thinkin d16a6 block rebuild with Ycp 75mm vitara low comp pistons on stock rods everything else in the block stock but rebuilt, with the stock z6 head swap chipped p28 ecu, might order a new chip for something closer to my build, pretty much what im trying to acomplish is getting it running and driving daily while i save for a turbo kit and more internals, one thing im not sure of if i use the z6 intake do i use the a6 injectirs or can i use a resistor delete adapter and use the z6 intake how it already is? anyone have any comments suggestions anything to add all help will be appreciated, please dont be vauge in response like i said ive help friends i have some knowledge but im not a pro at this, will be starting mechanics school in august. Thanks for everything.
BTW payed $300 for rolling chasis with d16a6 block and $400 for z6 head and everything else.
