how to repair jdm p30 ecu ??
Old Mar 3, 2017 | 12:03 PM
gizmogwaii's Avatar
Default how to repair jdm p30 ecu ??
hello ,
i have a jdm p30 that i bought from ebay , i fitted a demon in it and it doesnt work ,
i changed the q31 transistor allready , the car just doesnt fire ,
any ideas of components i could change to get it working ?
many thanks , tom
Old Mar 4, 2017 | 12:49 AM
gizmogwaii's Avatar
Default Re: how to repair jdm p30 ecu ??
couls anyone help please ? i would really appreciate it
Old Mar 4, 2017 | 03:16 AM
gizmogwaii's Avatar
i forgot to mention , the car runs perfectly with a p13 ecu , and i fitted a full milspec h22 swap harness so the problem isnt to do with wiring ...
Old Mar 4, 2017 | 04:11 AM
gizmogwaii's Avatar
well i realy appreciate all of your fast replies , thank you !!! :-/
Old Mar 4, 2017 | 05:47 AM
Txdragon's Avatar
So you bought said P30 and installed demon. Did it work before you installed demon?
Old Mar 4, 2017 | 07:06 AM
gizmogwaii's Avatar
Hi, thanks for your answer,
I never tried the ecu before fitting the demon...
Old Mar 4, 2017 | 07:10 AM
Txdragon's Avatar
So now we have established that the P30 is of questionable functionality, what steps did you follow to install the demon board?
Old Mar 4, 2017 | 07:12 AM
Txdragon's Avatar
And PLEASE post pictures of the insides of the ECU with the demon board and such. Thanks!
Old Mar 4, 2017 | 07:34 AM
gizmogwaii's Avatar
Old Mar 4, 2017 | 07:36 AM
gizmogwaii's Avatar
Old Mar 4, 2017 | 07:39 AM
gizmogwaii's Avatar
I followed a tutorial to fit the demon, and it connects to Neptune ok, I asked at moates for help and they told me that the demon was working fine, i am pretty sure that my connections are OK, the p13 was working fine so I suppose it is the P30, what do you think?
Old Mar 4, 2017 | 07:45 AM
gizmogwaii's Avatar
Old Mar 4, 2017 | 07:47 AM
Txdragon's Avatar
Very likely to be something with the ECU itself, especially if demon communicates ok with Neptune.
Old Mar 4, 2017 | 07:48 AM
gizmogwaii's Avatar
i do have a jdm p72 with a dead board for any spare components i could use ...
Old Mar 4, 2017 | 07:49 AM
gizmogwaii's Avatar
my first question was what are the components that could fail , not to diagnose that my ecu is faulty ... i obviously knew that ...
Old Mar 4, 2017 | 07:57 AM
gizmogwaii's Avatar
Old Mar 4, 2017 | 08:00 AM
Txdragon's Avatar
The capacitors are the largest problem in these things. Quite a few in my old P06 tested bad..
Old Mar 4, 2017 | 08:02 AM
gizmogwaii's Avatar
i changed the main capacitor in c27 allready , any others i should change ?
Old Mar 4, 2017 | 08:04 AM
gizmogwaii's Avatar
any transistors i should look at in particular too ?
Old Mar 4, 2017 | 08:15 AM
Txdragon's Avatar
Moates sells a rebuild kit for just a couple bucks. I'd look into one of those. Pretty much all caps.
Old Mar 4, 2017 | 08:18 AM
Txdragon's Avatar
My bad.. It's Phearable.net I saw them..
Ecu Chipping Hardware :: Obd1 ECU Capacitor Replacement Kit - Engine Parts & Tuning Solutions - Products - Phearable.net
Old Mar 4, 2017 | 08:24 AM
7rrivera7's Avatar
...1st mistake
Old Mar 4, 2017 | 08:26 AM
gizmogwaii's Avatar
as the p30 map isnt for a h22 i didnt want to try it without demon
Old Mar 4, 2017 | 08:32 AM
gizmogwaii's Avatar
Originally Posted by 7rrivera7
...1st mistake
so what do you think the problem is ?
Old Mar 4, 2017 | 08:40 AM
gizmogwaii's Avatar
should i take the bridge off j1 and try the ecu ?
