96 Gsr won't start after running for a while
Old Mar 2, 2017 | 09:54 PM
dc2lee's Avatar
Default 96 Gsr won't start after running for a while
So my 96 gsr runns good I'm throwing a po113 code IAT sensor high circut I'm gonna change that tomorrow, but my symptoms are: after a while i just let it idle and warm up then when i shut the car off and turn it back on only sometimes when it wants too, i have too pump the gas to get it to start and it takes 3 or 4 times of cranking it and pumping the gas like the cars flooding out even, it just dies right away.... then it starts, i rev it a little, then it runs great again. do you think after i fix that iat sensor it should be fine or what are ur thoughts on it...
Old Mar 4, 2017 | 12:40 AM
holmesnmanny's Avatar
Default Re: 96 Gsr won't start after running for a while
Sometimes on some cars it's possible to swap the iat connector with something else. Check to be sure that didn't happen.
C4AcuraDC2
May 13, 2015 09:55 PM
b.baker.13
May 17, 2012 08:22 AM
ja20_eg
34
Nov 7, 2011 07:45 PM
